G'day all,
Can anyone tell me any settings regarding setting my XD v8 ute up on the front end with the Camber and Toe in.
I regulary use the car on Drive days at the Creek. I have Konis all round, 27mm front sway bar, 22mm rear sway bar, Leaf springs modified to sit lower on rear, all new ball joints and front end components. When the car was originally done for camber and toe in, it was spot on, but now have had it done again and doesnt feel as responsive. Does anyone know what Dicky and all the other ford XD guys used back then regarding settings???
Regards
Shane
BSR Twin System (tm)
Best palce to check factory wheel alignment specifications is in a factory workshop manual. It should give you camber, castor, toe in and king pin angles. Hope this helps as I don't have an XD manual.
Cheers.
