1 - 9 of 9 Posts
· Registered
Hi guys ive just had a 9 inch diff made up for my xe (witch has been an absolute nightmare from the start) and when ive gone to put the watts linkage on it is about 2 inches further back at the diff pivot point than at the chassis bracket points,,has anyone come across this before,,am i missing something ,,or is it normal to just twist the brackets so it lines up??
cheers Marty
· Registered
Noo the centre pivot on the diff housing in the centre of the diff, (back of the diff centre area) is further back because of the larger crownwheel i guess.
Marty
· Registered
Discussion Starter · #5 ·
thanks brenden, yer ill see if anyone has had this problem or have the same setup,,there must be a few people with 9 inch diffs in xe,s
cheers Marty
· Registered
Discussion Starter · #7 ·
Its sorted thanks brenden,,i cut the bracket off were the pivot point seats and welded it closer to the diff housing,,(it didnt need to be mounted so far back) and it looks alot closer to factory now
1 - 9 of 9 Posts
