1 - 16 of 16 Posts
Falcon 2.. Ferrari 0 hehe
i got an XE and my mate got a VL...
he keeps on sayin his car is faster, which it is in a race, but he has got 3.5 gears, in his...
how can i quickly cheaply add more rwkw to stop his sayin that a holden is betta than a ford, and for him to start respecting my car?
also 2 more things...
1 when the auto is cold, will it show that its got more fluid than when its hot? after i warm it up, therei s nothing on the dipstick, but if the car is cold, its overfull?????
2 where do i start looking for a rev limiter? i wanna limit it to 5000.. 200 above redline....
YES its a 5 Speed!!
your trannys low... to check the oil they should be warm, engine running, left in park... this should give u an accurate reading to the level of oil... hope it helps
thats why, i want a rev limiter
so i dont blow it
kickerinthegutsbarry
Three numbers for you 3 5 and 1!
i have a vl. vl's are slow. if you want cheap mods.. do the usual shit like build yaself a cold air intake. new gears for the xe shouldnt be too expensive, try getting yourself like 3.9's or 4.11's or something like that which is near the 4's. maybe even an lsd unit from a fairmont? alot of people will say not to do this because it takes off the topend speed, but then again, how often do you go topspeed?
you could probably pick up a stall converter relatively cheaply as well, try 2500 or so.
good luck with the race :D
Are we there yet?
Put in a manual, LSD, Extractors, exhaust, and make sure the motor is tuned, and you should beat him no worries.
If you want more, as suggested above, three numbers 3 5 1....
it doesnt make sense that you get more oil when cold, cause everything expands when heated.
check when warm on a level grade, cycle through the gears and isnt it leave it in nutrual when checking?
Are we there yet?
It's to do with the oil running back into the pan after the car has been sitting for a while.
And I reckon that you check the oil with the engine off on XD-XF Falcons, have a look on the dipstick, it has the checking instructions written on it.
Discussion Starter #13
new plans
i got some new numbers and letters today
3 months
500 bux
302 windsor + FMX
= FUN!
next question, can you have a windsor in an xe? they come with v8, but clevo, not windsor... will it matter?
its got an lsd at the moment.... pitty its an xe, not d, i could have an old ltd with a 9" for 500 bux as well, only its had an engine fire, and needs sum work.... this ute is mad
its got a new holley 600, but he is taking it off, :( gonna have a 2bbl, mild cam, and small stally..... hehehe, bye bye vl
Bourbon powered V8
If you beat Ferarris, why even bother trying to beat a VL? What a waste of time.
Good luck with the V8 conversion - should provide a bit more oompf!
V8 would do the trick,if tuned properly,for the 6 a zorst ,air induction,tuned,diff,trans service and with yours a good carby wouldnt be too bad either..
wreckers are the best way to deal with cheap mods..
good luck..
Discussion Starter #16
hmmmm...... ferrari blood..... i still wish we had mums old xd, and i was on my learners... the fun i had
new deal, if i provide 2 xe ghia headlight glasses, i can get the ute for 300 bux :D
now, to scoure the wreckers hehehe
all i will, HOPEFULLY need is an accelerator cable, v8 bieng longer, and a 3 core radiator and a thermo switch for my fan MAD
hmmm.. gotta mild cam, small stally, its a ute, so hopefully got a better ratio, and hope its lsd
1 - 16 of 16 Posts
