pR()rN_*
Hey all this relates directly to my performance dreams so I thought I'd ask in here.
Does anyone know the setup for the XF EFI?
I know it runs the EEC-IV ecu but I need to know the following things.
1: Did it run a maf sensor?
2: Did it have sequencial fuel injection?
If this is the case I may be able to investigate the fuel maps and tables of the XF ECU to allow people to start using this ECU for tweecer and EEC-tuner applications rather than stuff with the V8 mustang ECU's.
As far as I know the XF efi setup is a direct copy of the mustang 6cyl setup with new fuel maps.
If this is so I can simply grab the XF EFI injector loom to install sequencial injection to my EB project and grab a MAF sensor plug (have the maf but not the plug)
4.1 XFLOW EFi Turbo
Nah, they run a Vane Airflow sensor and the injection was plain injection, only the carby models run a MAF/MAP sensor.
Anyone can correct me if i am wrong.
pR()rN_*
ok but "plan injection"
Does that mean the ECU has 2 injector drivers or 6?
By drivers I mean does the ECU control the 6 injectors independantly?
