was looking at an xh ute the other day and noticed that it has a larger much more noticable buldge in it then the standard ef sedan/wagon if they share the same engines why would this be so and would it fit onto an ef sedan??
Formerly EAII_Fairmont
I think you will have a bit of trouble getting it onto a sedan. The EF front is just sort of grafted onto the XF style ute.
No longer around
yes the XH bonet will not fit a sedan nor will the guards, however the headlights and front bumper are straight swap over.
the extra bulge in the bonet on XH is so the bonnet will fit over the radiator suport and kinda sorta flow with the lines, no other reason.
ford did a verry lame update from XF to XG, then a half cocked update to make the XG into XH,
they should have made an all new ute with the intro of EA or EB IMO
