· Super Moderator
Does it run at all or just badly? Generally LPG cars aren't run enough on petrol, so the injectors will often clog up; it it runs at all try some fuel injector cleaner in the tank and fuel rail. Also how long since the fuel filter was changed? Other simply things to check are the fuel pump (listen in the boot to see if you can hear it running and check the fuel pressure) and O2 sensors.
