Hey all Just a thought while I was reading some of the posts around here.
With my up and comming turbo project I plan to have the ECU controlled by a mustang A9l ECU edited by tweecer.
Now I plan to do this in stages.
stage 1: get everything else ready ie respray and finish my suspension
stage 2: fit the tweecer and get the electronics ready (fit the MAF sensor I have)
stage 3: fit the turbo and the cooler (includes relocating the battery) and run low boost on stock motor.
stage 4: rebuild the other motor I have to take a lot more boost.
Now obviously the time gap between stage 3 and 4 will be a long one as the motor build will be costly and take a while.
Now with the A9L being a V8 mustang ECU I have 2 extra injector controllers I can either turn off or use to drive 2 extra injectors higher in the rev range.
Now I have a whole set of spare injectors at home.
I'm thinking for the mean time I'll run 2 extra stock injectors and then later on upgrade the fuel pump and run bigger injectors with the new motor.
Now heres the question.
Whadda ya recon?
Whadda ya recon?
