engine swap; no spark
4.6K views 7 replies 3 participants last post by  SHOZ123
#1 ·
ok the 92 engine is in the 95 taurus and all connected up
it has great fuel pressure-
but no spark
tested the module, is good
swapped distributor, no spark
swapped coil, no spark still
what the hell ?
anyone have any ideas ?
everything on the original 95 3.0 was fine it ran awesome until the broken radiator caused it to overheat and lockup
the 92 engine ran awesome as well
had to unplug everything including the controller boxes on the rad suport and remove them, to get the radiator out to have it repaired
we are out of ideas
is there something in these cars that can disable ignition but not fuel that i need to check/reset ??
is there something electrically different from 92 to 95 that we need to swap??
both 3.0L SOHC non-SHO
the entire swap was going fine until the O2 sensor broke off and then this, and also i must add that the motor starter on the Weaver/Lesson vehicle lift that this car is on fried tonight
after 12-13 years of use
this swap went from fine to crappy in quick order haha, coincidentally on a ford, of all makes lol :=PPPP
thanks for anything!!
#2 ·
lemme add a bit more info i found out today
compared part numbers at the store for 92 and 95 distributors
same part number
store says that 95 and 92 had a knock sensor and that 95 had a crank trigger sensor, but not 92
the original 95 enigne doesnt have either
neither does the 92 one
i tested for 12v+ at the distrib and at the primary coil and at the secondary coil
all is 12v+ good
still no secondary spark at all
all parts on both engines were known good and running great in the vehicles they were from, before the engine swap
its gotta be something really stupid
what else can i check for and how do i do that ?
anyone ??
thanks
#3 ·
another symptom:
not injecting fuel at injectors either!
spark plugs no fuel smell at all!
something is telling this car not to inject fuel or spark either
all parts are known good
no security system in this car that i can see
nothing in owners manual about any security either
no chip in key
WTF?
thanks!
#4 ·
no check engine light in RUN position
#5 ·
no engine light was the tip off that the computer was not powered
finally after checking the CCR and relays and wiring connectors found the black ground wire plug by the battery was corroded,
fixed
fired right up runs like brand new
damn
corrosion happens after sitting for a couple years
hum
delete thread if you want
thanks
#7 ·
lmao yeah
oh we have things like this happen all the time
lots and lots haha
always repairing vehicles on the side, for self or friends or co-workers and so on
engine swaps, tranny swaps, heater cores and so on
side work
thanks!
