'93 EB aircon vent control issue
1 reading
13K views 10 replies 6 participants last post by  SiX_iN_a_RoW
#1 ·
G'day all, just passing on a query from a visitor...
"Hi Jack
I just got an EB '93 GLi model, and came across your website when checking to see how to fix the aircond vent control which is stuck on "windscreen defrost" mode, and will not open the vents for normal cooling and other modes.
I have looked in the dashboard and am not sure if it is just a mechanically operated cable that has slipped, or if it is an electronic switch that needs repair or replacement.
Can anyone help?
Thanks
Phil"
#2 ·
Check the under bonnet vacuum hoses are connected, there are two black and one green, green goes t the heater tap/va;ve, one back goes to vacuum connection "cone" at the bacj of the MPFI manifold, the other black coonnects to a black rubber hose which in turn, connects to another vacuum connector cone located near the thermostat housing
#4 ·
hey, my 91 eb doesnt heat at all, ive tried all the modes and that, but i never get the car heated. and the actual heater fan makes really bad noises like something is stuck inside of it. it still works, but every few seconds it makes a noise like it is grinding against something, its pretty noisy. ive been told its an 8 hour job to have a look inside the heater box as the whole dash has to be taken apart. whats wrong with the heater?
#9 ·
Yeah my EA has done the same thing several times.
Carefull placement of the vacuum pipe near the firewall passenger side makes it stay longer.
Tho its easily bumped if i reach my hand down to check the aircon water outlet, or remove the plug for the ICS when adjusting base idle.
I now remember to check it after doing any work near there just incase
