After saying previously that mine auto has never given me a problem, a week later it did, its worn out, so ok time for a rebuild, now that i have found out all i need to know, i am passing it on to anyone who is interested.
Parts needed for complete rebuild of my transmission are
1 seal kit $110
1 Front band $30
1 Rear band $60
1 Full clutch Kit $60
I personally am going to rebuild my transmission myself, the way i see it, i can rebuild the transmission at least 5 times for the cost of getting someone else to do it.
The most common cause of auto problems are loss of oil pressure, which is normally caused by seals or for BTR's can be caused be checkballs and sometimes solonoids, but normally when solonoids are faulty they are stuck in high pressure mode's not low, so unless one is seized into low pressure than it shouldn't cause the transmission to burn out anything.
AU solonoids arn't necessarily better, and neither are holden ones, they are both used because they are cheaper. and it all depends on wether or not you are running an electronic shift kit.
structuly the auto's from EA to BA are all extremely similar, drums, clutches, bands are all the same, the only main differences are after EA the band adjustments were replaced with shim adjusters so the box has to be adjusted from in the pan, and changes to the valve body, as far as i know each different version of le has a different valve body, some are interchangable some are not. But primarily the valve bodies all work the same, and apply the same pressures to clutch's/bands.
V8's have a different S3 and S4 solonoids in them which apply higher pressure to clutch's and bands.
If there is any other diffences that people are aware of then please add in.
1 seal kit $110
1 Front band $30
1 Rear band $60
