How to turn off "Check Air Suspension" light on 03 MGM
1 reading
14K views 3 replies 2 participants last post by  R.S.LOGAN
#1 ·
First off let me say that I did do a search and didn't pop up anything. If I typed in something wrong my apologies but just trying to find a solution to this issue.
I recently did the air conversion to a coil spring set up on the rear of my 03 grand Marquis ultimate edition. I did a Google search and searched on multiple forums and could not find anything on how to turn off this light on 03up.
Any help would be MUCH appreciated!
#3 ·
Check from 4.44 secs on video , might help .
www.youtube.com/watch?v=GTP2pFCxB7s
Thanks For trying but that did not address my issue whatsoever.
I have already done the coil spring conversion and I know where the shut off switch is for the air compressor in the truck. What I need to know is how to shut off the light on my dash that says "check air suspension"
#4 ·
Mis read your post , cant say if this is true or not .
" For those of you with a '98 on, you are out of luck if you wish to disable "air suspension" indicator on dash. It is controlled by the ECM/BCM, and short of reprogramming the computer, there is no way to turn out the light. "
