1996 Ford Taurus GL How to Disable Open Door Chime?
18K views 4 replies 5 participants last post by  sleddinfool
#1 ·
I just bought one of these fine vehicles used and that has to be the most annoying thing ever while having the door open and the chime does not stop. Even my Dodge truck seat belt warning wasnt that bad. Anyways, is there an ignition trick or step by step to disable the warning or what fuse would kill it (and what else would I loose if I pulled it) Any help would be appreciated to forum newbie.
Thanks guys
:hy:
#3 ·
Came across this , not sure if it applies to your model / year or if it affects more than " door open " warning .
" Warning Chime"
Removal and Installation
The warning chime module is mounted on a bracket to the RH side of the steering column, on the instrument panel reinforcement.
The module is #10 in this picture.
Item Part Number Description
1 6C625 Low Oil Indicator Assy
2 14B193 Horn Relay Assy
3 14A323 Relay Panel Bracket Assy
4 14401 Wiring Assy
5 17D539 Wiper Control Module
6 5404304 Instrument Panel Assy
7 N803876-S36 Screw (2 Req'd)
8A N805375-S36MG Ground Screw
9 14401 Wiring Assy Ground (for Canadian Vehicles Only)
10 10D840 Chime Assy
11 18C641 Rear Window Defroster Timer (Sable)
12 14B193 Horn Relay Assy
#4 ·
Logan, doesn't apply to 96-2007 Taurus/Sable. Warning chime is part of the GEM.
#5 ·
Turn the ignition to thr run position. Using a small screwdriver/pick push up into the hole under the ignition kry/cylinder. At the =same time pull to remove the cylinder. When it slides out simply remove the orange plastic piece with a couple metal pieces attached. Toss it and slide cylinder back in.. All shoud be good. Kevin
