EA electronic timing reset
1.9K views 4 replies 3 participants last post by  Aussiblue
#1 ·
Hey there!
Having just replaced new head, dizzy, got the timing right, but still not starting. It's turning over, but just cant get there. My husband has been pulling his hair out!!
were told that he needs to reset electronic timing??? Have no idea, can anyone help?? He needs the car like, yesterday.
Thanks
#3 ·
Thanks for your quick reply!!
It is an MPEFI, and he only used the standard gaskets that came with the set. He said everything is firing, it is just the resetting of the computer that he's not sure of. Do you turn ign on,then lights and pump brake, then turn off lights and ign? Have heard a few different things to do, but just not sure which is right.
#4 ·
To reset the computer, disconnect the battery for at least an hour and pump the brakes to remove any residual. Then reconnect the battery and do the following sequence:
Idle in drive with air con on for 2 mins;
Idle in drive with air con off for 2 mins;
Idle in neutral with air con on for 2 mins;
Idle in neutral with air con off for 2 mins;
Drive the car under various conditions.
