Hi,
Recently got EAC Fail flashing on my dashboard. First time I ignored it because it didn't recur. A month later it comes up again twice in one day. Took it to local Ford dealer and they charged me £308 for a diagnostics, PCM software update and new throttle body. Drove it home and error recurred on the way; took it back. They tell me perhaps they didn't clear the codes and did it again. On the way home, error happens again. They take it back for an overnight stay and tell me the new throttle body was faulty so they replaced it. Error recurs the next day so I booked it in again. This time they tell me the throttle pedal is also faulty so they changed that along with another throttle body. Error happened again on the way home. Car is with them again and I expect this time it's going to be the EAC module being replaced. Does anyone know how much this costs? Also any further advice other than "don't go to Ford if you ever want a problem fixed without 60 or so return visits" as this is the only experience I've ever had with Ford garages.
p.s. I should add that after the fault occurs, the car plummets in speed as soon as you let go of the accelerator, then when changing gears downwards, the engine stalls leaving you with no braking and no power steering. When restarting the engine, it runs fine as if nothing happened.
Thanks
Stuart
Thanks
Stuart
