HELP, trying to identifya 351c
1 reading
13K views 8 replies 7 participants last post by  tinman351
#1 ·
Hi Guys i'm trying to identify what engine and heads i have in my 351, these are the engine numbers i can find JG71pt 81948k which i have worked out is from a 1974 Ford ltd, but the other numbers i have no idea the numbers are listed below, pleas help.
The block D AE-LA
3j7
and it has an R stamped below the above numbers
Below this is a strange circular plate with the numbers 1, 3, 5, 7, 9 all written around the circle.
On the heads all i can find is a raised 3 on the end of the head and a stamped number 1 half way along the head.
Any help with these numbers would be very helpfull, thanks
#3 ·
Are you trying to determine WHICH 351C or IF it is a 351C?
One of the easiest ways on a stock engine to determine IF it's a 351C would be to look at the firing order and the block/water situation.
The Firing Order of the 351C is: 1-3-7-2-6-5-4-8. The #1 plug in the 351C distributor is normally located at the 7 to 8 o'clock
position as viewed from above/rear.
Here are some other Firing Order's.....
• Ford (5.0L HO, 351W, 351M, 351C, 400): Counter-clockwise 1-3-7-2-6-5-4-8
• Ford: Counter-clockwise 1-5-4-2-6-3-7-8
The Cleveland will NOT have a water jacket in the intake manifold. IE the hose going to your heater core will come from the water pump and NOT the intake manifold. I'm not sure on a 351 modified.
If you take off the heads, things become a little more obvious. The ports and valves on a 351C are quite large compared to a 351W.
I'm not near any resource material, but if you still need help I'll do some digging when I have time.
#4 ·
I know it is a 351c but what i'm wanting to find out is what the other numbers mean, and how to identify what heads are on it eg. 2v or 4v, i've had a couple of guys look at it & have told me different things, one guy even told me it was a nascar block, so i'm just trying to establish what i've got.
#5 ·
Gday Dave,
It would appear that the block you have (D AE-LA 3j7) was cast on September 7, 1973. There appears to be a number missing between the D and the AE, are there any other numbers you can find? It is likely that the R indicates that you have 4V heads :hy: rather than 2V and you should be able to see either a 2 or a 4 cast into the diagonal corners of the head, visible without removing the heads from the block.
Hope this helps,
Mark
#7 ·
Sounds more like you have a 351M/400 or a 400FMX. To determine if it's a C or M, measure across the flat area in the center where the intake sits. The measurement from head bottom to head bottom should be 7 inches for a 351C and 8.5 inches for a 351M/400. Also the bellhousing pattern will be a small block pattern (approx 6-7" at top two bolts) for a 351C and a 400FMX(ultra rare engine). The big block pattern is what the 351M/400 has and is approx 8 inches at the top 2 bolts of the bell. Now for the heads. If they have a 2 cast into the corner without a dot, they are 2v non smog heads. With a dot, smog 2v. Same goes for the 4v heads. No dot, more than likely closed chamber heads. Pull the valve cover for casting verification. Should be D0ZE or D0AE. With a dot, it will be open chamber heads with massive ports.
Hope I didn't overload you with info.
