I have a '94 ford topaz. Horn doesn't work. Changed the fuse, still no avail. Solution?
My horn did never worked. After hitting a deer because I could not honk to scare it I looked into the problem. When taking the cover off the steering wheel, there is a plastic plunger inside a wire spring that makes contact with the metal on the horn when pressed. Mine was broken. This fixed and I have since scared many a deer away when I see them coming near the road. Good luck.davidperson said:I have a '94 ford topaz. Horn doesn't work. Changed the fuse, still no avail. Solution?
