Ford 150 won't start lots of new parts
3.3K views 9 replies 4 participants last post by  CatSkinner
#1 ·
Hey everyone so I am stumped on this.
I have a 1994 F150 manual.
It will not start. There is no cranking noise or any sounds.
I have already replaced the ignition lock cylinder, the battery, the starter solenoid, and the starter.
I am at a complete loss as to what it could be at this point.. and thoughts or suggestions would be awesome!
#4 ·
Well good news! This was it.... bad news.... now it seems I have 0 oil pressure and the truck won't stay running. :/
I think I should just sell this piece of shit.
Anyways what are your guy's thoughts on where to start on this.
Little info I was able to go about 30 miles no issue, started it up to come home got about 15 miles in gauge drops down and the engine starts to die out like it's out of gas. Then died completely with the gauge at 0.
Looking around looks like it could be something as simple as some wiring in the power distribution or replacing the oil pump. any quick suggestions would be awesome.. I really don't wanna swap that pump.
#6 ·
His 94 is OBD1 and should be able to get those codes at home.
Step 1 - Use a grounded test light inserted into the data link connector, which is usually under the hood near the battery.
Step 2 - Turn the key to the" ON" position this will initiate the code gathering sequence which be produced in the form of two digits.
Step 3 - The test light will begin to flash on, then off, when the flashing stops the first digit is complete, the system will then pause, and the second digit will begin. Example: Test light flashes twice, and pauses, then flashes six more times the code number is 26.
Step 4 - Once repairs have been made, to clear system, simply remove the negative battery cable for thirty seconds and reconnect.
There are 2 test modes, the KOEO (key on engine off) and the KOER (key on engine running). Both test modes should be used to get the accurate evaluation of the stored fault codes.
Code 11 means system is normal.
#8 ·
Bert, they didn't show on your post. I'll post them here.
Codes for OBD1 (Before 1996)
11 - System pass
12 - Idle control fault
13 - DC motor did not move
14 - engine rpm signal fault or PIP circuit failure
15 - EEC processor or power to KAM interrupted
16 - rpm to low to check oxygen sensor test or fuel control error
17 - CFI fuel control system fault or rich/lean condition indicated
18 - Ignition diagnostic monitor (IDM) circuit failure
19 - Cylinder identification (CID) sensor input failure
21 - Engine coolant temperature (ECT) out of self-test range
22 - Manifold absolute pressure (MAP) sensor circuit out of range
23 - Throttle position sensor out of self-test range
24 - Air charge temperature (ACT) sensor out of self-test range
25 - Knock not sensed during dynamic response test
26 - Transmission fluid temperature out of self-test range
28 - Loss of primary tach, right side
29 - Insufficient input from vehicle speed sensor
31 - EGR position sensor below minimum voltage
32 - EGR position sensor below closed limit
33 - Throttle position sensor noisy/harsh on line
34 - EGR valve circuit out of self-test range
35 - EGR valve circuit above maximum voltage
38 - Idle track switch circuit open
39 - AXOD torque converter or bypass clutch not applying properly
41 - Oxygen sensor circuit indicates system always lean
42 - Oxygen sensor circuit indicates system always rich
43 - Oxygen sensor out of self-test range
44 - Air injection control system failure
45 - Coil 1 primary circuit failure
46 - Coil primary circuit failure
47 - 4X4 switch is closed or oxygen sensor failure
48 - Coil primary circuit failure
49 - Electronic transmission shift error
51 - Engine coolant temperature sensor circuit open
52 - Power steering pressure switch circuit open
53 - Throttle position circuit above maximum voltage
54 - Air charge temperature circuit open
55 - Key power input to processor open circuit
56 - Mass air flow circuit above maximum voltage
57 - AXOD circuit failure
58 - Idle tracking switch circuit fault
59 - Automatic transmission shift error
61 - Engine coolant temperature circuit grounded
62 - Converter clutch error
63 - Throttle position circuit below minimum voltage
64 - Air charge temperature circuit grounded
65 - Charging system over voltage
66 - Mass air flow sensor circuit below minimum voltage
67 - Neutral/drive switch circuit open
68 - Transmission fluid temperature over temperature transmission shift error
70 - Data circuit communication link circuit failure
71 - Message center circuit circuit failure
72 - Insufficient manifold absolute pressure (MAP) change during dynamic response test
73 - Insufficient throttle position (TPS) change during dynamic response test
74 - Brake on/off (BOO) circuit open
75 - Brake on/off (BOO) circuit closed
76 - Insufficient air flow output change during test
77 - Brief wide open throttle not sensed during test
78 - Power interrupt detected
79 - A/C on/defrost on during self test
81 - Map has not changed normally
82 - Super charger bypass circuit failure
83 - OIC-low speed fuel pump relay circuit failure
84 - EGR vacuum regulator (EVR) circuit failure
85 - Canister purge circuit failure
86 - Shift solenoid circuit failure
87 - Fuel pump circuit failure
88 - Electro drive fan circuit failure
89 - Transmission solenoid circuit failure
91 - No oxygen sensor switching detected
92 - Shift solenoid circuit failure
93 - Throttle position sensor input low
94 - Torque converter clutch solenoid circuit failure
95 - Fuel pump secondary circuit failure
96 - Fuel pump secondary circuit failure
97 - Transmission indicator circuit failure
98 - Electronic pressure control circuit failure
99 - EEC has not learned to control idle
