A modular engine makes for many interchangeable components such as pistons, rings, connecting rods, bearings, oil pumps, valvetrain parts, water pumps, etc. However, not all components are interchangeable with the 4.6L car family of engines due to the desire to increase robustness in certain areas of the engines for the more severe usage they would expect to see in the trucks.
ajor points of interest on the modular engines:
* All cylinder blocks have deep skirts with cross-bolted main caps for rigidity
* DOHC engines have aluminum cylinder blocks
* SOHC engines have cast iron cylinder blocks
* All cylinder heads are aluminum
* All valvetrains are of the hydraulic roller-finger-follower type for reduced friction and zero maintenance
* All accessories are rigidly mounted directly to the block with no brackets for improved NVH and cost
* Very long head bolts are used to reduce distortion of the cylinder bores and provide improved sealing
